Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 11
Now for the fun part! Speakers are all well and good, but Alexa's true mouthpiece is the swivel-top volume control and light ring. Alexa acknowledges a voice command by changing the LEDs pointing toward you from blue to...lighter blue. The volume dial contains the user-interactive bits: the top portion spins freely, using a greased-up gear to turn an encoder...
  • Now for the fun part!
  • Speakers are all well and good, but Alexa's true mouthpiece is the swivel-top volume control and light ring. Alexa acknowledges a voice command by changing the LEDs pointing toward you from blue to...lighter blue.
  • The volume dial contains the user-interactive bits: the top portion spins freely, using a greased-up gear to turn an encoder...
  • ...which you can also control via voice command!
  • Pro tip: take the Echo out of its protective plastic covering before attempting volume level 10.
Insertar traducción aquí
