Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Use a plastic opening tool to gently lift the motherboard up and remove it from the front plastic case. Use caution when lifting the board since the speaker is attached.
  • Use a plastic opening tool to gently lift the motherboard up and remove it from the front plastic case.
  • Use caution when lifting the board since the speaker is attached.
Usa una palanca de desmontaje de plásticos para separar cuidadosamente la placa base de la carcasa frontal de plástico.
Ten cuidado al levantar la placa, ya que el altavoz seguirá unido a la carcasa.
