Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 4
Lay the Droid Maxx face down on the plastic surface to start removing the screws. Take the Torx T5 Screwdriver and carefully remove all the screws in the Droid Maxx’s motherboard. Note that there is a total of eight (11) black screws spread across the motherboard, four (4) at the top and four (4) at the bottom, and also two (2) silver screws located to the right lower part of the Droid Maxx. There is(1) screw holding the camera housing. Use a T4 screwdriver for this one screw.
Removing the Camera Back Housing
  • Lay the Droid Maxx face down on the plastic surface to start removing the screws.
  • Take the Torx T5 Screwdriver and carefully remove all the screws in the Droid Maxx’s motherboard. Note that there is a total of eight (11) black screws spread across the motherboard, four (4) at the top and four (4) at the bottom, and also two (2) silver screws located to the right lower part of the Droid Maxx.
  • There is(1) screw holding the camera housing. Use a T4 screwdriver for this one screw.
  • After removing all the screws, lift hold the Droid Maxx as in step 2
  • Locate two (2) tabs in the camera plastic housing , one (1) at each corner of the Droid Maxx
  • Take the Flathead driver and gently lift both tabs to release the camera housing. Be careful because these plastic tabs are very delicate and can break easily.
Insertar traducción aquí
