Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 5
Here is an example of what is possible for you to find when you remove the strainer. This car probably was not running when the strainer was removed.
  • Here is an example of what is possible for you to find when you remove the strainer. This car probably was not running when the strainer was removed.
  • Note - if you find more than a small amount of debris, consider running a biocide in your fuel tank, following the manufacturer's instructions for use. This amount of debris is likely from a microbial infection of the fuel.
Insertar traducción aquí
