Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 12 guías que incluyan este paso.
Inglés
Español
Paso 2
The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console. Use the flat end of a spudger to release the following latches: Above the front-facing USB ports.
  • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
  • Use the flat end of a spudger to release the following latches:
  • Above the front-facing USB ports.
  • Beneath the front-facing USB ports.
  • Above the Memory Unit slots.
Las carcasas superior e inferior se sujetan con varios pestillos, localizadas en la parte delantera y trasera de la consola. Estos pestillos deben ser desenganchados para separar la carcasa superior de la consola.
Usa el extremo plano de un spudger para soltar los siguientes pestillos:
Encima de los puertos USB delanteros.
Debajo de los puertos USB delanteros.
Encima de las ranuras de la unidad de memoria.
