Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 6
Slightly lift, but do not remove, the upper end of display assembly. Do not remove the front panel entirely. It is still attached by a connector.
  • Slightly lift, but do not remove, the upper end of display assembly.
  • Do not remove the front panel entirely. It is still attached by a connector.
  • If you are reusing the home button flex cable, be careful not to sever the cable from the home button. Adhesive can cause the cable to rip apart from the home button. While the home button will still work, the fingerprint scanner will not.
Insertar traducción aquí
