Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 3
Use the pick to pry the display by sliding the pick in the direction shown. Make sure you pry the display around the edge of the phone. At the bottom of the screen there is a thin metallic strip that connects the display to the motherboard, and it can be easily damaged. If any resistance is encountered, stop prying and reapply heat to continue prying.
  • Use the pick to pry the display by sliding the pick in the direction shown.
  • Make sure you pry the display around the edge of the phone. At the bottom of the screen there is a thin metallic strip that connects the display to the motherboard, and it can be easily damaged.
  • If any resistance is encountered, stop prying and reapply heat to continue prying.
Insertar traducción aquí
