Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 2
Lift the display up from its lower edge and rotate it toward the top of the Touch.
  • Lift the display up from its lower edge and rotate it toward the top of the Touch.
  • The next few steps require removal of components under where the display normally sits. Be sure to hold the display to avoid putting tension on the delicate display ribbon cable.
  • Remove the seven Phillips screws securing the metal display tray to the rear panel. They may be very tight; watch carefully to make sure you don't strip them.
  • The two darker screws belong in the two holes in the tray nearest the bottom edge of the Touch.
Insertar traducción aquí
