Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
Use an opening pick to slowly separate the Lightning connector and headphone jack cable from the rear case. Carefully work the pick down the right side of the Lightning connector and headphone jack cable, making sure to stop right as you hit the bottom. Carefully work the pick down the right side of the Lightning connector and headphone jack cable, making sure to stop right as you hit the bottom.
  • Use an opening pick to slowly separate the Lightning connector and headphone jack cable from the rear case.
  • Carefully work the pick down the right side of the Lightning connector and headphone jack cable, making sure to stop right as you hit the bottom.
Insertar traducción aquí
