Saltar al contenido principal
Inglés
Español
Paso 2
Using a Phillips-Head #1 screwdriver, unscrew the four outer 1.0 mm screws and remove with tweezers. Unscrew the 0.6 mm screw located in the center of the battery case. Remove the back cover carefully; there are many wires that connect it to the device.
  • Using a Phillips-Head #1 screwdriver, unscrew the four outer 1.0 mm screws and remove with tweezers.
  • Unscrew the 0.6 mm screw located in the center of the battery case.
  • Remove the back cover carefully; there are many wires that connect it to the device.
  • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
Insertar traducción aquí
