Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 10 guías que incluyen este paso.
Inglés
Español
Paso 6
Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be. Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case. Rotate the spudger upward to release the last clip.
  • Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
  • Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
  • Rotate the spudger upward to release the last clip.
  • The spudgers holding the top and bottom clips apart may be removed.
Insertar traducción aquí
