Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery. Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly. Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
Separating Panels
  • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
  • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
  • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
  • Carefully separate the front panel from the back panel.
  • Notice that the front and back panels are still connected by a ribbon cable.
Insertar traducción aquí
