Saltar al contenido principal
Inglés
Español
Paso 5
Insert your Micro-SIM Card into the hole you cut out of the SIM. If the Micro-SIM doesn't fit, you may need to cut away more plastic with the knife to enlarge the hole. If you cut the hole slightly too big, put a piece of tape over the back of the SIM-Card (the side without the gold contacts) to hold the Micro-SIM in place.   Trim away any excess tape with the knife.
  • Insert your Micro-SIM Card into the hole you cut out of the SIM.
  • If the Micro-SIM doesn't fit, you may need to cut away more plastic with the knife to enlarge the hole.
  • If you cut the hole slightly too big, put a piece of tape over the back of the SIM-Card (the side without the gold contacts) to hold the Micro-SIM in place. Trim away any excess tape with the knife.
  • You may want to add some tape even if the hole is the correct size; this will help prevent the Micro-SIM from coming loose inside the phone and getting jammed when you try to remove it.
Insertar traducción aquí
