Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 8
Slide the point of a spudger behind the shield plate to gently lift the home button cable up off of the front panel. If the cable doesn't peel away easily, use a little heat from an iOpener or hair dryer to soften the adhesive underneath. Remove the LCD shield plate.
  • Slide the point of a spudger behind the shield plate to gently lift the home button cable up off of the front panel.
  • If the cable doesn't peel away easily, use a little heat from an iOpener or hair dryer to soften the adhesive underneath.
  • Remove the LCD shield plate.
  • During reassembly, make sure to seat the home button connector on the shield behind the small indentation in the plastic.
Desliza la punta de un spudger detrás de la placa protectora para levantar suavemente el cable del botón de inicio hacia arriba y sacarlo del panel frontal.
Si el cable no se despega fácilmente, use un poco de calor de un iOpener o un secador de pelo para suavizar el adhesivo que se encuentra debajo.
Retira el protector del LCD
[* black] Slide the point of a spudger behind the shield plate to gently lift the home button cable up off of the front panel.
[* icon_caution] If the cable doesn't peel away easily, use a little heat from an iOpener or hair dryer to soften the adhesive underneath.
[* black] Remove the LCD shield plate.
+[* red] During reassembly, make sure to seat the home button connector on the shield behind the small indentation in the plastic.
