Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 6
Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel. If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
  • Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
  • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
Utiliza el punto fino de un spudger para cuidadosamente separa el cable del botón de inicio del adhesivo asegurandolo al panel frontal.
[* black] Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
+[* icon_caution] If the cable doesn't separate easily, apply heat using an [product|IF145-198-4|iOpener|new_window=true] or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
