Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 2
Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Slowly pull the adhesive tab away from the battery, toward the bottom of the iPhone. To avoid tearing the adhesive strip, be careful not to snag it against the vibrator or other components near the battery.
  • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
  • Slowly pull the adhesive tab away from the battery, toward the bottom of the iPhone.
  • To avoid tearing the adhesive strip, be careful not to snag it against the vibrator or other components near the battery.
  • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
  • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  • If the strip breaks, carefully try to retrieve it with your tweezers (without damaging the battery) and continue pulling. If the strip breaks off underneath the battery and can't be retrieved, continue with the steps below.
Intenta mantener las tiras planas y sin arrugas durante este procedimiento; las tiras arrugadas se pegarán y se romperán en lugar de salir limpiamente.
Lentamente, retira la pestaña adhesiva de la batería, hacia la parte inferior del iPhone.
Para evitar rasgar la tira adhesiva, ten cuidado de no engancharla contra el vibrador u otros componentes cerca de la batería.
Tira firmemente, manteniendo una tensión constante en la tira hasta que se deslice entre la batería y la caja trasera. Para obtener los mejores resultados, tireade la tira a un ángulo de 60º o menos.
La tira se estirará a muchas veces su longitud original. Continúa tirando y vuelve a tomar la tira cerca de la batería si es necesario.
Si la tira se rompe, trata de recuperarla con tus pinzas (sin dañar la batería) y continúa tirando. Si la tira se rompe debajo de la batería y no se puede recuperar, continúa con los pasos a continuación.
