Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 3
When you feel increased resistance from the adhesive strip, pull it gently around the lower right corner of the battery. Continue pulling the adhesive tab upward and away from the right edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone. Don't allow the adhesive strip to snag on the battery connector, or it may tear or break off.
  • When you feel increased resistance from the adhesive strip, pull it gently around the lower right corner of the battery.
  • Continue pulling the adhesive tab upward and away from the right edge of the battery, allowing it to slowly slide out from between the battery and the rear case, until the strip comes free from the iPhone.
  • Don't allow the adhesive strip to snag on the battery connector, or it may tear or break off.
Cuando sientas una mayor resistencia de la tira adhesiva, tire suavemente alrededor de la esquina inferior derecha de la batería.
Continúa tirando de la pestaña adhesiva hacia arriba y lejos del borde derecho de la batería, permitiendo que se deslice lentamente entre la batería y la carcasa trasera, hasta que la tira se libere del iPhone.
No permitas que la tira adhesiva se enganche en el conector de la batería, ya que podría desgarrarse o romperse.
