Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 11 guías que incluyen este paso.
Inglés
Español
Paso 7
Remove the following five screws securing the Wi-Fi antenna to the logic board:
  • Remove the following five screws securing the Wi-Fi antenna to the logic board:
  • One 2.3 mm Phillips
  • Two 1.6 mm Phillips
  • One 1.4 mm Phillips
  • One 4.8 mm Phillips
  • When re-assembling, start off with replacing the 4.8 mm Philips screw first, then the 2.3 mm. This is to ensure there is no mix-up, and avoid rendering the LCD and digitizer useless.
  • Also make sure to put the long 4.8 mm Philips back in correctly when reassembling. This is the ground for the Wi-Fi antenna and is often the culprit if you are having bad Wi-Fi reception after reassembly.
Insertar traducción aquí
