Saltar al contenido principal
Inglés
Español
Traduciendo paso 18
Paso 18
Nexus 9 Repairability: 3 out of 10 (10 is easiest to repair) The rear case is secured with clips, so it can be easily removed without heat or tools (just don't lose your rear-facing camera).
  • Nexus 9 Repairability: 3 out of 10 (10 is easiest to repair)
  • The rear case is secured with clips, so it can be easily removed without heat or tools (just don't lose your rear-facing camera).
  • The battery is easy to get to, but glued in place. Thankfully, the adhesive is not so strong as to require heat to separate.
  • The interior is a maze of tape and thin, delicate cables, making disassembly and reassembly difficult and perilous.
  • The LCD is fused to the front glass, so you'll need to replace both components in the event of a cracked screen.
  • On top of that, the display glass is insanely very solidly glued to the midframe, making the replacement difficult unless you can source the whole assembly.
Insertar traducción aquí
