Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a heat gun to soften the adhesive underneath the camera/microphone cover. Pry the camera/microphone cover off the case with a metal spudger and remove it. It is extremely difficult, if not impossible, to avoid damaging the iPod case near the camera. While this will not affect the iPod's functionality, it will hurt its cosmetic appearance.
  • Use a heat gun to soften the adhesive underneath the camera/microphone cover.
  • Pry the camera/microphone cover off the case with a metal spudger and remove it.
  • It is extremely difficult, if not impossible, to avoid damaging the iPod case near the camera. While this will not affect the iPod's functionality, it will hurt its cosmetic appearance.
  • You can try this alternative method for removing the cover:
  • Use a hot glue gun to apply a bead of glue across the cover.
  • Move the nozzle in the glue for 20 seconds to heat the lens adhesive holding the lens in place.
  • Press a spudger into the hot glue and hold it in place until the glue cools and hardens.
  • Pull on the spudger with firm steady force, while using a fingernail to pry on the cover edge.
Usa una pistola de calor para suavizar el adhesivo debajo de la cubierta de la cámara / micrófono.
Saca la cubierta de la cámara / micrófono de la caja con un spudger de metal y extráigala.
Es extremadamente difícil, si no imposible, evitar dañar la carcasa del iPod cerca de la cámara. Si bien esto no afectará la funcionalidad del iPod, dañará su apariencia estética.
