Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 8
With one iPod opening tool still between the glass and outer case, insert a second iPod opening tool in between the front glass and outer case, on the left side. Slide the second iPod opening tool toward the bottom of the device to remove the adhesive.
  • With one iPod opening tool still between the glass and outer case, insert a second iPod opening tool in between the front glass and outer case, on the left side.
  • Slide the second iPod opening tool toward the bottom of the device to remove the adhesive.
Con una herramienta de apertura de iPod aún entre el cristal y la carcasa exterior, inserta una segunda herramienta de apertura de iPod entre el cristal frontal y la carcasa exterior, en el lado derecho.
Desliza la segunda herramienta de apertura del iPod hacia la parte inferior del dispositivo para quitar el adhesivo.
-[* black] With one iPod opening tool still between the glass and outer case, insert a second iPod opening tool inbetween the front glass and outer case, on the right side.
+[* black] With one iPod opening tool still between the glass and outer case, insert a second iPod opening tool in between the front glass and outer case, on the left side.
[* black] Slide the second iPod opening tool toward the bottom of the device to remove the adhesive.
