Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Your next step is to remove the five screws holding down the motherboard.  Use the PH1 philips screwdriver. Once you have removed the five screws you may lift the motherboard off of the front case. At this point you may also remove the dial pad. It simply lifts off.
  • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
  • Once you have removed the five screws you may lift the motherboard off of the front case.
  • At this point you may also remove the dial pad. It simply lifts off.
  • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
  • The whole phone is now disassembled at this point.
Insertar traducción aquí
