Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Traduciendo paso 6
Paso 6
Remove the battery from the iPhone.
Adhere the battery, disconnect it, and continue reassembling your device.
[* black] Remove the battery from the iPhone. |
[* icon_note] If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the the ribbon cable. |
[* icon_reminder] If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery. |
[* icon_reminder] Before you adhere the replacement battery, temporarily reconnect the battery connector to the logic board socket. This ensures that the battery is properly aligned in its recess. |
[* black] Adhere the battery, disconnect it, and continue reassembling your device. |
[* icon_reminder] If your new battery doesn’t have adhesive preinstalled, refer to [guide|56465|this guide] to replace the adhesive strips. |
[* icon_reminder] Perform a [guide|44409|hard reset] after reassembly. This can prevent several issues and simplify troubleshooting. |
