Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 4
Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone. Use the flat end of a spudger to disconnect the antenna connector from its socket on the back of the logic board.
  • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
  • Use the flat end of a spudger to disconnect the antenna connector from its socket on the back of the logic board.
Con cuidado, coloca la placa lógica dada vuelta con la porción superior descansando contra la caja trasera del iPhone.
Usa el extremo plano de un spudger para desconectar el conector de antena de su zócalo en la parte trasera de la placa lógica.
