Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 23 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
If you don't have an iSclack, use a single suction cup to lift the front panel:
Manual Opening Procedure
  • If you don't have an iSclack, use a single suction cup to lift the front panel:
  • Press a suction cup onto the screen, just above the home button.
  • Be sure the cup is pressed securely onto the screen to get a tight seal.
  • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
Si no tienes un iSlack, utiliza una sola ventosa para levantar el panel frontal:
Presiona una ventosa contra la pantalla, justo arriba del botón de inicio.
Asegúrate que la ventosa esté presionada firmemente contra la pantalla para obtener un cierre hermético.
Si la pantalla está completamente destrozada hasta el punto de que una ventosa no se pegue, utiliza cinta de embalaje transparente o similar para cubrir la pantalla. A veces, incluso, puedes tirar hacia arriba usando sólo la cinta sin usar la ventosa.
[title] Manual Opening Procedure
[* black] If you don't have an iSclack, use a single suction cup to lift the front panel:
[* black] Press a suction cup onto the screen, just above the home button.
[* icon_note] Be sure the cup is pressed securely onto the screen to get a tight seal.
[* icon_note] If the screen is completely shattered to the point thatyour display is badly cracked, [guide|103486|covering it with a suction cup will not stick, uselayer of clear packing tape or similartape|stepid=193571|new_window=true] may allow the suction cup to coveradhere. Alternatively, very strong tape may be used instead of the screen. Sometimessuction cup. If all else fails, you can even pull up using just the tape without usingsuperglue the suction cupcup to the broken screen.
