Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 9
Paso 9
Lift the front panel out of the inner case, minding the cable still routed through the bottom of the Evo. Carefully de-route the front panel ribbon cable through the slot in the inner case.
  • Lift the front panel out of the inner case, minding the cable still routed through the bottom of the Evo.
  • Carefully de-route the front panel ribbon cable through the slot in the inner case.
  • Remove the front panel.
  • Notice the four (4) clear plastic hooks that are adhered behind the menu buttons. Look closely. Each one is shaped differently and in a particular orientation.
  • If the replacement front panel does not have these installed already, carefully remove and transfer them from the old panel to the replacement.
Insertar traducción aquí
