Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 7
Pry up the front panel along the right edge using the method described in previous steps. Eventually work around the entire perimeter of the front panel until it is lifted slightly from the inner case. Don't try to completely remove the front panel just yet. Its ribbon cable is still attached to the inner case.
  • Pry up the front panel along the right edge using the method described in previous steps.
  • Eventually work around the entire perimeter of the front panel until it is lifted slightly from the inner case.
  • Don't try to completely remove the front panel just yet. Its ribbon cable is still attached to the inner case.
Insertar traducción aquí
