Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Heat up a pen-tip, soldering iron and lightly touch the solder on the end of the pickup wire. Gently pull on the pickup wire while melting the solder. After the wire is separated from the selector switch, remove any broken wire strands in the leftover solder with needle-nose pliers, while still heating the solder.
  • Heat up a pen-tip, soldering iron and lightly touch the solder on the end of the pickup wire.
  • Gently pull on the pickup wire while melting the solder.
  • After the wire is separated from the selector switch, remove any broken wire strands in the leftover solder with needle-nose pliers, while still heating the solder.
Insertar traducción aquí
