Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body. Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack. Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
Remove the Pickguard
  • Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body.
  • Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
Insertar traducción aquí
