Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar. If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier. If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
Remove the Strings from the Bridge
  • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
  • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
Insertar traducción aquí
