Saltar al contenido principal
Inglés
Español
Paso 2
If the key you are removing is the spacebar (like you see pictured here), you should find a single spring placed on one of two circular spots located one the right and left side underneath the key.
The Spacebar Spring
  • If the key you are removing is the spacebar (like you see pictured here), you should find a single spring placed on one of two circular spots located one the right and left side underneath the key.
  • Remove the spring and place it to the side so it doesn't get lost.
  • It does not matter which of the two circular spots the spring is on.
  • There is only one spring per spacebar. If the spring is missing, don't worry — the spacebar will work fine without it — but it will work better when the spring is attached.
Insertar traducción aquí
