Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Insert the plastic opening tool or spudger into the side of the key you wish to remove, and press downward on the far end of the tool to pry the key up. You may also pry the key up by simply using your finger and/or fingernail, however, it is easier to use an opening tool.
Removing a Key
  • Insert the plastic opening tool or spudger into the side of the key you wish to remove, and press downward on the far end of the tool to pry the key up.
  • You may also pry the key up by simply using your finger and/or fingernail, however, it is easier to use an opening tool.
Insertar traducción aquí
