Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 4
To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable. Pull the ribbon cable to remove it from the connector. Repeat the exact steps above for the other ribbon cable.
Detaching keyboard Ribbon Cables
  • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
  • Pull the ribbon cable to remove it from the connector.
  • Repeat the exact steps above for the other ribbon cable.
  • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
Insertar traducción aquí
