Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver. Disconnect the battery from the location indicated by a yellow circle Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
Removing the Battery
  • Remove all of the 3 mm screws indicated by a red circle with the #00 Philips Screwdriver.
  • Disconnect the battery from the location indicated by a yellow circle
  • Now you may remove the battery. The replacement battery should be 3.7 Volts and 25.9 kWh.
Insertar traducción aquí
