Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body. Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack. Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
Remove the Pickguard
  • Gently lift up on the pickguard. With the screws removed, it should be loose, and easily pulled off of the guitar body.
  • Carefully rotate the pickguard away from the guitar. Notice the electronics. There is a wire that runs through the body to the output jack.
Insertar traducción aquí
