Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Pull up on the SATA power cable connector to disconnect it. Unplug the SATA data cable connector by depressing its locking tab and pulling straight up on the connector. Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
  • Pull up on the SATA power cable connector to disconnect it.
  • Unplug the SATA data cable connector by depressing its locking tab and pulling straight up on the connector.
  • Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
Tira hacia arriba del conector del cable de alimentación SATA para desconectarlo.
Desenchufa el conector del cable de datos SATA levantándolo.
Quita el cable SATA del conjunto de la placa lógica para quitarlo del medio y evitar que se dañe.
[* black] Pull up on the SATA power cable connector to disconnect it.
[* black] Unplug the SATA data cable connector by lifting it updepressing its locking tab and pulling straight up on the connector.
[* black] Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
