Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Inglés
Español
Paso 2
Use an opening pick to slowly separate the Lightning connector and headphone jack cable from the rear case. If the adhesive feels hard to slice, apply additional heat and try again. Carefully work the pick down the right side of the Lightning connector and headphone jack cable, making sure to stop right as you hit the bottom.
  • Use an opening pick to slowly separate the Lightning connector and headphone jack cable from the rear case.
  • If the adhesive feels hard to slice, apply additional heat and try again.
  • Carefully work the pick down the right side of the Lightning connector and headphone jack cable, making sure to stop right as you hit the bottom.
Usa una púa de apertura para separar lentamente el conector Lightning y cable del conector de auriculares de la caja trasera.
Si te resulta difícil hacerlo debido al adhesivo fijador, aplica algo más de calor y prueba de nuevo.
Con cuidado desliza la púa por el lado derecho del conector Lightning y cable conector de auriculares, asegúrate de detenerte cuando llegues a la parte inferior.
