Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray. RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM. To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
Remove the RAM
  • Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
  • RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM.
  • To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
  • Re-insert the RAM access door back into its place.
Retira la memoria RAM agarrandola con ambas manos para que salga derecha.
Los módulos RAM están diseñados para ser insertados de una sola manera. Observa con atención el diseño antes de colocarlo.
Inserta la memoria RAM en la ranura deseada y presiona firmemente hasta que quede asegurada en su lugar.
Reinserta la tapa de la memoria RAM
+[title] Remove the RAM
[* black] Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
[* icon_reminder] RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM.
[* black] To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
[* black] Re-insert the RAM access door back into its place.
