Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port. You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
Open the RAM door
  • While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
  • You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
Manteniendo la pantalla firmemente, use una punta plana para hacer presión en el botón de apertura del compartimento de la memoria RAM. Este se encuentra localizado justo por encima del enchufe.
Quizás debas presionar bastante fuerte hasta que se habra la puerta del compartimento.
+[title] Open the RAM door
[* black] While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
[* icon_note] You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
