Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 20 guías que incluyan este paso.
Inglés
Español
Paso 8
Remove the 2.8 mm Phillips screw securing the optical drive.
  • Remove the 2.8 mm Phillips screw securing the optical drive.
  • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
  • Do not over-tighten this screw when re-mounting. You could break the plastic enclosure.
  • After removing the screw, push the metal tab backwards, towards the fan, to release the front of the optical drive.
Insertar traducción aquí
