Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 4
After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board. Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution. This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
  • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
  • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
  • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
Una vez que retiramos la cubierta de la placa madre, notamos que la batería está intacta y tiene una cinta negra adherida a ella, que está montada en la placa lógica.
Usando el spudger, comienza a levantar la batería con cuidado desde el lado opuesto a la cinta. Ten en cuenta que hay un adhesivo de alta calidad que mantiene la batería en su compartimento, así que proceda con precaución.
Esta batería no está encerrada en una cubierta dura, por lo que es suave y maleable. Se debe tener precaución durante la extracción para no causar daños permanentes.
