Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 99 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the following ten screws securing the lower case to the upper case:
Lower Case
  • Three 13.5 mm (14.1 mm) Phillips screws.
  • Seven 3 mm Phillips screws.
  • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
Remueve los siguientes diez tornillos que aseguran la cubierta trasera a la cubierta superior.
Tres tornillos tipo Philips (punta cruz) de 13.5 mm (14.1 mm)
Siete tornillos tipo Philips (punta cruz) de 3mm
[title] Lower Case
[* black] Remove the following ten screws securing the lower case to the upper case:
[* orange] Three 13.5 mm (14.1 mm) Phillips screws.
[* red] Seven 3 mm Phillips screws.
[* icon_reminder] When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
