Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 19 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Tilt the battery away from the logic board enough to access the battery cable connector.
  • Tilt the battery away from the logic board enough to access the battery cable connector.
  • Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
  • Pull the battery cable connector away from the center of the logic board.
  • If you're installing a new battery, you should calibrate it after installation:
  • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
  • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Incline la batería fuera de la placa lógica lo suficiente para acceder al conector del cable de la batería.
Extraiga el conector del cable de la batería de su zócalo en la placa lógica y extraiga la batería de la carcasa superior.
Tire del conector del cable de la batería lejos del centro de la placa lógica.
[* black] Tilt the battery away from the logic board enough to access the battery cable connector.
[* black] Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
[* icon_note] Pull the battery cable connector away from the center of the logic board.
[* icon_reminder] If you're installing a new battery, you should [[Battery Calibration|calibrate]] it after installation:
[* black] Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
[* black] If you notice any unusual behavior or problems after installing your new battery, you may need to [https://support.apple.com/en-gb/HT201295|reset your MacBook's SMC|new_window=true].
