Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 4
Remove the back plate using the plastic opening tool. There is a lip on each side, and both must be pried up. You can work your way around the edges after prying the two sides.
  • Remove the back plate using the plastic opening tool.
  • There is a lip on each side, and both must be pried up.
  • You can work your way around the edges after prying the two sides.
Insertar traducción aquí
