Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 4
Slowly work your way across the lower edge of the front display bezel until it is free from the display assembly. Be sure to pry up as far away from the LCD as possible, as it extends below the edge of the front display bezel. When you get about half way across, pry up from the other side of the front display bezel's lower edge to ease the process.
  • Slowly work your way across the lower edge of the front display bezel until it is free from the display assembly.
  • Be sure to pry up as far away from the LCD as possible, as it extends below the edge of the front display bezel.
  • When you get about half way across, pry up from the other side of the front display bezel's lower edge to ease the process.
Insertar traducción aquí
