Inglés
Español
Paso 4
De-route the antenna cables from the groove cut into the rear display bezel. Carefully pull the antenna cables out from under the frame attached to the rear display bezel and remove them from the display assembly.
  • De-route the antenna cables from the groove cut into the rear display bezel.
  • Carefully pull the antenna cables out from under the frame attached to the rear display bezel and remove them from the display assembly.
Insertar traducción aquí
