Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger. Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
Disconnect Charge Port
  • Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
Levanta el cable conector del vibrador de su zócalo en la placa lógica con el extremo plano de un spudger.
[*title] Disconnect Charge Port
black] Pry the vibratorcharge port connector cable up from its socket on the logic board with the flat end of a spudger.
