Saltar al contenido principal
Inglés
Español
Paso 3
The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button. The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button.
  • The next step requires peeling one end of the home button cable (highlighted in red in the second picture) that is affixed to the back of the display assembly with strong adhesive. We highly recommend using an iOpener to heat the bottom of the display assembly, directly on top of the home button.
El siguiente paso requiere pelar un extremo del cable del botón de inicio (resaltado en rojo en la segunda imagen) en la parte posterior del ensamblaje de la pantalla con un adhesivo fuerte. Recomendamos encarecidamente utilizar un iOpener para calentar la parte inferior del ensamblaje de la pantalla, directamente en la parte superior del botón de inicio.
