Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Remove the front-facing camera and sensor cable assembly off the display assembly.
  • Remove the front-facing camera and sensor cable assembly off the display assembly.
  • Replacement assemblies may or may not come with the speaker mesh already attached. If it's missing, save your old one and re-use it. You can separate it with some heat from a hair dryer and gentle prying or pulling with tweezers.
Remueve el ensamblaje del cable de sensor y la cámara frontal del ensamblaje de pantalla.
[* black] Remove the front-facing camera and sensor cable assembly off the display assembly.
+[* icon_reminder] Replacement assemblies may or may not come with the [product|IF269-019|speaker mesh|new_window=true] already attached. If it's missing, save your old one and re-use it. You can separate it with some heat from a hair dryer and gentle prying or pulling with tweezers.
