Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 6
Carefully use the tip of a spudger to finish separating the home button from the front panel. Carefully use the tip of a spudger to finish separating the home button from the front panel.
  • Carefully use the tip of a spudger to finish separating the home button from the front panel.
Desliza con cuidado la punta de un spudger debajo del perímetro del botón de inicio para separarlo del ensamblaje del panel frontal.
-[* black] Carefully run the tip of a spudger underneath the perimeter of the home button to separate it from the front panel assembly.
+[* black] Carefully use the tip of a spudger to finish separating the home button from the front panel.
